roshester quad jet carb. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2011, 10:11 PM
Gota roshester quad jet carb. It's not running so great,the truck wont run unless i up some fuel down the carb then hook the fuel line bak up.. pulled the filter out of it and it was squashed up inside the housing.pulled it out, it made not diffence. Just a case for a clean do you think?
Old 08-31-2011, 04:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Needs a rebuild. If the fuel drains out overnight and you have to crank it over for a long time, or prime it by pouring gas down the carb , the main wells are leaking- a common problem w/the earlier Q-jets.
Tell us about the induction system on the engine below. I see a Q-jet throttle plate, then what else is there?
Old 08-31-2011, 04:16 AM
poor mans injection.
Ok that sounds like the problem i am having. i can crank the engine all i like and it wont start. but once i prime it with gas it will run. tho it doesn't want to, i have the rev's turned up to keep it alive.
the system below is a dedicated lpg intake."poor mans injection"
there is no petrol carb on it. it makes it run alot better then a duel fuel arangement and i dont have any problems of over fueling or straving the engine when on rough unlevel turrain.
Old 08-31-2011, 07:06 AM
willowbilly3's Avatar
Last journal entry: Body mods
I have rebuild hundreds of Q jets and never saw the fabled main well plug leakage everyone blames them for. It seems to me like they found out it was actually the fuel going back down the line and came up with the fuel filter with the little check valve in it. Almost every Q jet problem I have seen was just a dirty carb and more commonly, problems with the choke controls. They also wear out the throttle shaft bushings but that mostly causes idle issues.
Old 08-31-2011, 12:04 PM
First question is, do you have a Rochester Quadrajet spread bore or a 4GC square bore (called QuadJet by Rochester). Yeah, it's confusing, but these are two completely different carbs.
I agree about the leaking main well plugs. This ONLY applies to the early 1966-67 Qjets that used the pressed in sheet metal cap plugs. All Qjets built since 1968 use spun-in aluminum plugs that DO NOT leak.
Old 08-31-2011, 04:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Couple things here:
The man said he has a Q-jet. Instead of doubting him, I will believe he knows the difference between a 4G and a 4M.
Originally Posted by cobalt
...the main wells are leaking- a common problem w/the earlier Q-jets
The leaking wells became a problem w/the intro of the Q-jet-- in 1965. Q-jets between 1965-'68 w/the cup plugs virtually ALL leaked, and anyone who's dealt w/these carbs knows this very well.
Carb kits from then to this day have included those (worthless) black triangular tampons made to stop the well leak. For a week or two, anyway.
The aluminum sweged plugs are much more reliable, BUT- as has been found time and time again- they have to be verified to be leak-free, because they DO leak occasionally. No carb rebuilder worth his salt would build a carb w/o checking them over. I have a ground-down tap in my carb tools used for nothing but threading the well holes for plugging.
Old 09-01-2011, 03:31 PM
Originally Posted by cobalt327
Couple things here:
No, he didn't. Read his O.P. again. He specifically said a "Quad Jet". Some 4GCs have "Quad Jet" cast into the body (and some have "4 Jet"), hence my question. Remember what happens when one ASSumes...
Old 09-01-2011, 03:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My mistake, if it IS a mistake. The OP did say "pulled the filter out of it and it was squashed up inside the housing." The 4G on my Buick 215 had an inline glass filter OEM. I don't know of any 4G's that used a filter like a Q-jet that would be in a housing, and that could be "squashed up"- back then many filters were sintered and to be squashed up would take a hammer! That doesn't mean there aren't any- just that I've not seen one. Are there any like that? If not, I think I'll call it a Q-jet. If there are, then I guess he'll (the OP) will need to clear things up.
Take care.
Old 09-02-2011, 11:33 AM
No mistakes to worry about, I just wanted the OP to clarify what carb he actually had, which I what I asked originally.
Old 09-02-2011, 04:59 PM
this carb is a quadrajet with small primarys and large secondarys
Old 09-02-2011, 05:02 PM
this one has electronic feed bak and a built in filter housing. it has a roughly 30mm long round paper type filter in it.
Old 09-02-2011, 05:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Are you using the PCM and the engine mounted sensors, etc. to control the carb or are you wanting to run the feedback carb without the computer? Or is the hard starting the main problem, or ?
Old 09-02-2011, 09:48 PM
the starting problem is the main problem. i'm actually unsure of what is set up with the feed system; but i know what ever it is it was working. the main problem i have is the starting problem. It could be a vacuum leak so some discription, so that is the first place i will head i think.
Old 09-02-2011, 09:49 PM
what is the pcm and engine mounted sences for?
Old 09-02-2011, 10:37 PM
SSedan64's Avatar
The CCC QuadraJet is computer controlled, it uses feedback from the Engine Sensors to the ECM/EngineControlModule to tune the Carb. If the ECM or Sensors are deleted it will not operate.
http://arrc.epnet.com/autoapp/9100/9...JUSTMENTS_.htm
Carb Question Holley Quad Jet Brandonion1985 Engine 18 01-06-2011 10:52 AM
4412 carb or 750 4 barrel quad david73 Engine 0 06-22-2010 07:00 PM
quad cam gm v6 emc racing Engine 6 01-10-2009 10:33 PM
Dual Quad vs Single big carb 69ChevelleAddict Engine 10 05-29-2006 07:28 PM
305 quad carb 69GrandPrix Engine 1 12-07-2004 06:11 PM
