Rotating Assembly Kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2005, 10:15 PM
juiced66malibu's Avatar
I am purchasing a new rotating assembly kit for a 383. In regards to forged pistons what is better, the dome or flat top? My car will see track time but I would like to use street gas 92 octane.Also in regards to the short block what is the better choice? 2-piece or 1-piece seal?
Actually, I would like a 4340 crank but is it forged as well? I am going to use 200hp of juice.
Also, can anyone recommend a great forged rotating short blocks?
Old 10-10-2005, 07:39 AM
benwantland's Avatar
Two points to consider:
a) I doubt you can get any kind of streetable compression ratio using dome pistons.
b) Assuming you can manipulate other factors to keep the compression ratio the same, flat top pistons are theoretically less detonation-prone than pop-ups.
balanced rotating assembly????? engineman302 Engine 4 01-25-2005 01:03 PM
rotating assembly firestone Engine 1 11-21-2004 09:56 AM
rotating assembly question richardson110 Engine 4 10-03-2004 08:47 PM
Turbo SBC Rotating Assembly KA67_72 Engine 7 07-02-2004 09:29 PM
Balanced Rotating Assembly chevytech Engine 5 05-12-2004 07:54 PM
