Rotisserie - Door Bracing - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2009, 08:01 PM
outoftouch's Avatar
I am putting my 65 Satellite 2 dr HT on a rotisserie very soon.
I will have the usual items off the car, trunk, hood, fenders and doors. I see that some guys weld a brace across the doors for support and some don't use anything ?
What are you guys doing for this ? If you are bracing the doors with a piece of square tubing or similar where are you welding it ? ex. top of the door frame, middle of the door frame ???
More details the better..... thx
Old 10-08-2009, 11:22 AM
Last journal entry: 50 Ply wagon
With both doors off you should tack weld bracing between the doors. Weld a brace from drivers side to pass side through the inside. I like to put one near the roof line and one above the hump in the floor.
Old 10-08-2009, 11:32 AM
boatbob2
bracing
HI,before removing body from chassis,i weld braces from bottom to top and top to bottom (large X) in 4 places front of doors to opposite side (and rear,then X across door frame,on both sides)
Old 10-08-2009, 12:11 PM
outoftouch's Avatar
Does it matter if it's a unibody car ? Does that still need bracing ?
Tilter; Rotisserie; or Ramp? ndustrl Garage - Tools 40 01-27-2010 09:44 PM
rotisserie balance, hints wanted firstgenbird Body - Exterior 3 12-10-2005 08:32 AM
Camaro rotisserie joe72 Garage - Tools 6 02-15-2005 06:12 PM
Locating the center, for a rotisserie.... Pencilneck314 Garage - Tools 7 02-18-2004 10:08 AM
Patch panel replacement on frame or rotisserie? GMW Body - Exterior 2 10-08-2003 07:15 PM
