Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rotisserie question
Old 01-17-2013, 04:13 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Getting a body balanced on a rotisserie is a bit of a trial and error deal..the adapter is mounted to the body so the axis is centered side to side and then with an adjustable mount the weight is centered in the vertical axis of rotation..When you build yours some sort of pin or brake needs to be installed so you can lock the body in one place while you are working. after one spot is completed then unlock the body and turn it ti the next spot and work on that until it is done and can come off the rotisserie..
Sam
