Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rotor to fit an Olds stub axle?
Old 07-08-2010, 01:01 PM
joe_padavano joe_padavano is online now
Originally Posted by Holdon
Unfortunatly it is illegal to machine the stub axle as I have already inquired about doing that. Will check out some of those rotors you mentioned anyway though. Thanks.
The only machining that MIGHT be required is to turn down the non-structural pilot on the face of the flange, the only purpose of the pilot is to center the drum or rotor on the hub. Obviously you don't want to do anything that might weaken the hub. In reality, the hole in the center of the rotor will likely be larger than the pilot on the hub. You are more likely to need a machined ring between the rotor and the hub.
