disc brake
Are the front brake drums removeable, bolted or riveted to the hubs.? I would check out some of the rear rotors from front wheel drive big gm cars of the 80's Scarebird has a lot of disc conversion kits and list one for your olds and had a demo of a 60. very similar.
All you need is a rotor that fits a 5 x 5" bolt circle, with a center pilot that is close enough that you can machine either the rotor or the hub to fit. As noted, many of the FWD GM large cars in the 1970s and 1980s had rear rotors that should work on your front hubs. Check a late 70s Toronado or Eldorado with rear discs. Here are the dimensions for a 1977 Eldo rear rotor:
| Will An Olds 455 Engine Fit In My 69 Firebird | daveh | Engine | 5 | 11-11-2005 01:38 AM |
| Cadillac Engine for a rambler? | Farthingfan | Hotrodding Basics | 10 | 09-17-2005 09:44 PM |
| frames 37 chevy going on a 38 olds | 38 old coupe | Suspension - Brakes - Steering | 0 | 05-24-2004 01:45 PM |
| King-pin fit into chromed beam axle? | Limey Simon | Suspension - Brakes - Steering | 2 | 11-06-2002 04:40 PM |
| will this rear axle fit my AD / spring selection | solowookie | Transmission - Rearend | 1 | 03-06-2002 02:51 PM |
