Rotor Swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-11-2011, 12:36 PM
Rotor Swap
Have an old 54 Ford P/U. It has an old Mustang II front end (Mercury Bobcat 73). Need rotors that will give me a bigger wheel and 5 bolt Ford pattern. I have heard that Granda rotors work, but I need some more advise and directions. Your help would go a long ways.
Old 11-24-2011, 01:02 PM
Wiki Edits: 27
check speedway
Speedway motors now has a kit to give the old ford pickup big pattern, also gm 4 3/4 or ford pass 4.5 pattern. with bigger rotors you will need calipers and mounting plate, at one time small 5 bolt ranger rotors were reduced in Dia but I wouldn't use small rotors on a truck.
rotor swap 66GMCPickup Suspension - Brakes - Steering 11 05-12-2008 02:29 PM
86 Chevy front rotor swap JMillerJr76 Suspension - Brakes - Steering 2 02-19-2008 09:31 AM
Front Rotor Swap 83_Chevy Suspension - Brakes - Steering 5 03-11-2006 01:21 PM
hub/rotor i.d. help please alteredpilot Suspension - Brakes - Steering 4 06-17-2005 09:43 AM
Ranger / Pinto rotor swap mr.Pinto Suspension - Brakes - Steering 1 07-26-2004 11:20 PM
