rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2010, 07:55 PM
rotors
recently purchased a72 vega super gas car.car has rotors but no calipers. bought a set of calipers for a 72 vega,but they won't fit. rotors have casting number 359731,are 4 lug 4inch centers 7/16x20 and are vented.anyone know what these rotors fit, or where i can find out?thanks
Old 08-04-2010, 08:08 PM
Rickracer's Avatar
ASE Master Tech, Fabricator
Last wiki edit: Taurus 2-speed fan control wiring diagram Last photo:
I don't know about the casting numbers off the top of my head, but it sounds like you've probably got some later model Monza rotors, maybe '75 or '76? An even better idea is to swap on some S10 spindles and brakes. You can make the S10 ball joints fit the Vega control arms, or, they make sleeves to make the Vega ball joints fit the S10 spindles.
Old 08-04-2010, 11:20 PM
ericnova72's Avatar
More for Less Racer
Sounds like Monza to me too, I know my original brakes on the front of both of the 72-73 Vega's I have are a solid thin rotor, non-vented. One car is getting the S-10 spindle upgrade, the other a straight axle.
The ball joint adapter sleeves for putting S-10 spindles on are at www.v8monza.com. Have seen them on Ebay also.
Old 08-05-2010, 09:48 AM
jon72vega's Avatar
WOW, I could have had a V8!
X 3 for Monza.
Here's a link to how you can finish converting your Vega to the Monza front brakes as I did this to mine.
http://1972vega.wordpress.com/projec...-front-brakes/
Jon
Difference in rotors? gsrokmix Suspension - Brakes - Steering 8 04-17-2008 05:08 PM
GM rotors with Ford bolt pattern junkyardjeff Suspension - Brakes - Steering 4 01-26-2008 04:24 PM
cross drilled rotors on a 67 chevelle m.docken Suspension - Brakes - Steering 13 02-23-2007 07:26 PM
blank rotors Mr Miyagi Suspension - Brakes - Steering 1 03-13-2005 08:28 PM
American Made Mustang II Rotors Sweet-34 Suspension - Brakes - Steering 2 05-17-2004 05:29 PM
