-   -   Rotors (http://www.hotrodders.com/forum/rotors-190963.html)
cujo77 01-18-2011 08:17 AM
Rotors
I have a '74 Vega, does anyone know if the rotors from S-10 fit a Vega? Or do you need the spindles and disc brakes from the S-10? Thank You
joe_padavano 01-18-2011 08:34 AM
Here's a hint. Go to Rockauto.com and look up the inner and outer wheel bearings for both vehicles. If they are the same, there's a CHANCE that the rotors fit. If not, there's no chance at all.
Of course, the even more obvious problem is that the caliper mounts are integral to the spindle and the S-10 rotors are larger than the Vega rotors, so there's no way to move the calipers to fit.
lanier ledford 01-18-2011 12:12 PM
rotor change ?
I'd worry more about the caliper hook up than the bearings, get the spindle outside measurement and the inside rotor measurement and check with a bearing co. for bearings. Are the rotors the sme dia. ? if so you maybe in luck. lol
joe_padavano 01-18-2011 12:55 PM
Vega:
http://extranet.soleniuminc.com/Cent...s/12062001.jpg
S-10:
http://extranet.soleniuminc.com/Cent...s/12062013.jpg
freedom53 01-18-2011 02:18 PM
Dimension charts
hello joe - where do you find the dimension charts that you have posted. it would be nice to be able to access them when trying to cobble something together. thanks! brian
joe_padavano 01-18-2011 02:27 PM
Here ya go:
http://www.centricparts.com/
Click on the "Select your vehicle" button on the left side of the page and a new window will open that allows you to select the part (rotors, calipers, drums, etc) and year/make/model. The resulting list will provide links to images of the parts.
ericnova72 01-18-2011 02:41 PM
Go to www.v8monza.com, all the info you seek is there. The S-10 swap requires you to use the S-10 spindle, a '75-up Vega/Monza lower ball joint, and a set of the tapered ball joint stud adapters sold at V8Monza.
Your other choice is to look for '75-up Monza spindles and brakes, these have a better vented rotor and better caliper, but are still 4 bolt wheel pattern. Getting pretty hard to find in usable shape however.
The S-10 swap is really the most economical way to get 5 bolt wheels and better brakes and is pretty easy to do.
freedom53 01-19-2011 06:55 AM
thanks joe
