Rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2011, 09:17 AM
Rotors
I have a '74 Vega, does anyone know if the rotors from S-10 fit a Vega? Or do you need the spindles and disc brakes from the S-10? Thank You
Old 01-18-2011, 09:34 AM
Here's a hint. Go to Rockauto.com and look up the inner and outer wheel bearings for both vehicles. If they are the same, there's a CHANCE that the rotors fit. If not, there's no chance at all.
Of course, the even more obvious problem is that the caliper mounts are integral to the spindle and the S-10 rotors are larger than the Vega rotors, so there's no way to move the calipers to fit.
Old 01-18-2011, 01:12 PM
Last wiki edit: Removing stuck fasteners
rotor change ?
I'd worry more about the caliper hook up than the bearings, get the spindle outside measurement and the inside rotor measurement and check with a bearing co. for bearings. Are the rotors the sme dia. ? if so you maybe in luck. lol
Old 01-18-2011, 01:55 PM
Vega:
S-10:
Old 01-18-2011, 03:18 PM
freedom53's Avatar
Last journal entry: A Few Years Later...
Dimension charts
hello joe - where do you find the dimension charts that you have posted. it would be nice to be able to access them when trying to cobble something together. thanks! brian
Old 01-18-2011, 03:27 PM
Here ya go:
http://www.centricparts.com/
Click on the "Select your vehicle" button on the left side of the page and a new window will open that allows you to select the part (rotors, calipers, drums, etc) and year/make/model. The resulting list will provide links to images of the parts.
Old 01-18-2011, 03:41 PM
ericnova72's Avatar
More for Less Racer
Go to www.v8monza.com, all the info you seek is there. The S-10 swap requires you to use the S-10 spindle, a '75-up Vega/Monza lower ball joint, and a set of the tapered ball joint stud adapters sold at V8Monza.
Your other choice is to look for '75-up Monza spindles and brakes, these have a better vented rotor and better caliper, but are still 4 bolt wheel pattern. Getting pretty hard to find in usable shape however.
The S-10 swap is really the most economical way to get 5 bolt wheels and better brakes and is pretty easy to do.
Old 01-19-2011, 07:55 AM
freedom53's Avatar
thanks joe
Help ID these rotors and how do they come off? Yegster Suspension - Brakes - Steering 11 08-08-2010 05:03 PM
rotors atcoed Suspension - Brakes - Steering 3 08-05-2010 10:48 AM
TCI rotors cornfieldcars Suspension - Brakes - Steering 4 09-19-2005 08:21 PM
Rotors... bg Suspension - Brakes - Steering 4 04-25-2005 02:33 PM
Rotors? TonyMac Suspension - Brakes - Steering 3 07-01-2003 05:25 AM
