Rotors... - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2005, 08:38 PM
bg's Avatar
bg bg is offline
Rotors...
Does anybody know of a web site that would have measurements on rotors? I am trying to find out what i have so i can order new drilled & slotted rotors..
I have a Ford 9 inch rear end and a nova front clip and aftermarket control arms with GM spindles..... The bolt pattern is 5 on 4 3/4
Any Help
Thanks
Bg
Old 04-22-2005, 03:42 AM
astroracer's Avatar
Take 'em to an autoparts store. They should be able to match them up...
Old 04-22-2005, 06:52 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
bg,
Try checking out:
www.wilwood.com or
www.ssbrakes.com
Bob
Old 04-25-2005, 11:01 AM
johnsongrass1's Avatar
Race it, Don't rice it!
5 on 4 3/4 is the big GM rotor. Used on trucks and full size cars.
Old 04-25-2005, 01:33 PM
I think you got that mixed up.
5 on 4.75" is the midsize pattern used on vettes, f-bodies, g-bodies, s10's, etc...
It is 5 on 5" that is used on fullsize cars and trucks.
Do the rear rotors have more then 1 bolt pattern in them? If they do they are most likely a Ford rotor (like 96-up explorer) redrilled to fit the GM bolt pattern. For the front rotors see the list above. AFAIK no one other then GM used 5 on 4.75"
blank rotors Mr Miyagi Suspension - Brakes - Steering 1 03-13-2005 08:28 PM
redrilled rotors 6speedwagon Suspension - Brakes - Steering 1 11-20-2004 08:44 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
American Made Mustang II Rotors Sweet-34 Suspension - Brakes - Steering 2 05-17-2004 05:29 PM
buying rotors APACHEMAN Suspension - Brakes - Steering 5 08-06-2003 07:51 PM
