rotors n brakes upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 06:07 AM
I want 2 put brakes pads n slotted/crossed rotors on the rear what kind of car that i can get them off that will be compatible wit my rearend. or do i have 2 buy the kit? i have a 73 impala custom wit the old brake shoes n drums.
Old 07-22-2008, 06:12 AM
Bluejackets67's Avatar
You'll probably better off buying a kit, Stainless Steel Brake Corp. has a kit for the rear, upgraded slotted/cross drilled rotors and pads for the front. www.ssbrakes.com Put in your make, model and year and it will pull up a list of parts available. Keep in mind that you will have to replace your master cylinder and proportioning valve for the capacity that the rear dis brakes will need.
1962 Buick upgrade questions for engine and brakes EddyBBB General Rodding Tech 1 09-10-2007 05:24 PM
Brakes Upgrade Joe Viss Suspension - Brakes - Steering 4 01-20-2006 06:36 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
Brakes locking up in non ABS system nprfan Suspension - Brakes - Steering 9 08-24-2005 12:37 PM
1966 Chev PU upgrade to dual master cylinder for existing brakes Bannear Suspension - Brakes - Steering 7 10-23-2002 01:15 PM
