Rough engine idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2009, 04:58 PM
HR23TB's Avatar
Weekend Gas Hog
Rough engine idle
I was cruising around last weekend a showing off a little with a few burnouts when the lights turned green. when i came up to the last light, the engine was idleing really rough. i crippled my way on home and since then, the engin idles very rough, revving up or slowing down without any throttle work. I changed the plugs and the coil, but that didnt help. what do you think i did and how can i test it for sure?
It's a basic chevy 350 in a t-bucket, so nothing extra added on.
Old 05-19-2009, 05:10 PM
American Muscle's Avatar
305 Turbo-Fire 240hp
What type of carb are you running? Could be a fuel issue. Try putting HEET(gas treament) in your gas tank and drive for a while to get it running through. This should clean out any blockage in the carb if there is any. Thats what I would do next
Old 05-19-2009, 06:16 PM
HR23TB's Avatar
Weekend Gas Hog
Its an Edelbrock 650. it does sit for a while in between sunday drives. I will give it a try. I was a little worried something internal was starting to go. the engine is still realtively new, only a few thousand miles on it, but it was first started back in 1999 after a total re-build from the shortblock up.
Old 05-19-2009, 06:24 PM
Zimmo's Avatar
If it still runs rough, put a timing light on it & see if it's moving around. Something stuck after your little WOT stink, may be the mech advance.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
1995 Mercury Mystique rough idle when stopped in Drive jordan2011 Engine 1 10-29-2008 02:16 PM
454 Ignition Timing Question leejoy Engine 58 09-13-2008 08:40 AM
Do I need vacuum advance? (Long Post) Chevy21 Engine 49 10-25-2007 12:51 PM
Vacuum adv.. underdog305 Engine 58 01-30-2007 11:19 AM
