he motor ran smooth before you pulled dist check that.
might be a tooth or 2 off.
I would remove all plugs and turn motor till #1 is at TDC
then reinstall distributor and wires.
but first double check your firing order ( could be as simple as that)
firing order here:
http://www.boxwrench.net/specs/chevy_sb.htm
