-   -   Rough Idel Of a chevy 350 (http://www.hotrodders.com/forum/rough-idel-chevy-350-a-157168.html)
likemike 04-20-2009 08:59 AM
I have a 87 chevy and i just put a new 350 longblock in about 6 months ago. I have added a hei mallory distrubitor and a new edelbrock 600 carb. I have a ruff idel now and caint seem to find out the problem. Can sum one help with the rough idel?
MI2600 04-20-2009 09:35 AM
Couple of ideas:
If the roughness smooths out as rpms increase, check for a vacuum leak.
Pull the plugs and look for fouling.
dawg 04-20-2009 11:03 AM
he motor ran smooth before you pulled dist check that.
might be a tooth or 2 off.
I would remove all plugs and turn motor till #1 is at TDC
then reinstall distributor and wires.
but first double check your firing order ( could be as simple as that)
firing order here:
http://www.boxwrench.net/specs/chevy_sb.htm
DoubleVision 04-20-2009 05:32 PM
You have adjusted the idle mixture? What intake is on the engine? is it a stock intake with a adapter so the edelbrock carb will fit? Need more details.
