Rough Idel Of a chevy 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-20-2009, 08:59 AM
I have a 87 chevy and i just put a new 350 longblock in about 6 months ago. I have added a hei mallory distrubitor and a new edelbrock 600 carb. I have a ruff idel now and caint seem to find out the problem. Can sum one help with the rough idel?
Old 04-20-2009, 09:35 AM
MI2600's Avatar
Member# 3287
Couple of ideas:
If the roughness smooths out as rpms increase, check for a vacuum leak.
Pull the plugs and look for fouling.
Old 04-20-2009, 11:03 AM
dawg's Avatar
NAVY VETERAN
he motor ran smooth before you pulled dist check that.
might be a tooth or 2 off.
I would remove all plugs and turn motor till #1 is at TDC
then reinstall distributor and wires.
but first double check your firing order ( could be as simple as that)
firing order here:
http://www.boxwrench.net/specs/chevy_sb.htm
Old 04-20-2009, 05:32 PM
DoubleVision's Avatar
You have adjusted the idle mixture? What intake is on the engine? is it a stock intake with a adapter so the edelbrock carb will fit? Need more details.
Hi. just wondering why the 350 chevy small block is so good... judgedredd Hotrodders' Lounge 78 06-25-2010 08:01 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 16 08-07-2007 03:45 PM
El Camino Engine - 350 Chevy or 455 Pontiac bjam2 Engine 17 01-06-2007 09:11 PM
New 350 Chevy runns rough and won't idle 66nova Engine 3 08-01-2002 01:22 PM
