Rough idle 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2012, 04:06 PM
Hi im working on an 87 olds cutlass with a 383 stroker in it.
It runns great at idle under no load but as soon as in gear it wont idle that great and u have to feather the gas.
The good part is as soon as u stand on it it screems.
Any ideas as to what i can do ??
Old 12-21-2012, 04:14 PM
vinniekq2's Avatar
what do you have your static timing set at?carb? FI?
Old 12-21-2012, 04:18 PM
Carb not sure no timing light to check
Old 12-21-2012, 04:19 PM
vinniekq2's Avatar
advance the timing and see if that helps
Old 12-22-2012, 12:15 AM
bjautos7's Avatar
sounds like a vaccum leak , check intake and all vaccum lines. also how big is the cam as your still in your Torque convertor could be to low.
Old 12-22-2012, 10:51 AM
What stahl are you running? What cam? Engines with high lift cams dont make any power until you come off idle.A stock stahl will kill the motor evey time you put it in gear.
Old 12-22-2012, 07:52 PM
I dont remember thestall on the converter but when u put it in gear it will jump, and then almost die out. In nutraul or park will idle at about 1 grand.
Thats the complaint. I bought the car this way but i replaced the 350 trans in it with a 700 r4. The trans has ben worked with a shift kit for racing but i have to change the gears in the rearend for highway.
Old 12-22-2012, 08:23 PM
bjautos7's Avatar
i would start by finding out what was the still speed your Torque convertor had in the 350 trans , or info on the cam.
Old 12-22-2012, 11:17 PM
Greg T's Avatar
www.krusinklassics.net
Drop the idle down to 700 and adjust the idle mixture screws to start with. Go from there.
Chevy 383 stroker oil pressure drops at w.o.t idle and curise is find Danny Scott Engine 4 04-05-2012 04:24 PM
Rough idle, high idle in park, stalls in gear.. Help! ratmaro Engine 16 03-23-2012 06:29 PM
383 Vortec Holley carb rough idle question Cousin_Joe Engine 11 06-04-2008 08:01 PM
1981 Gm 3.6 V6 Rough Idle And High Idle nomaddaddy Engine 1 11-15-2007 10:49 PM
Rough idling 383 stroker. Wolverine1221 Engine 12 10-01-2007 09:06 AM
