Rough idle, high idle in park, stalls in gear.. Help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2011, 07:39 PM
ratmaro's Avatar
79 305 sbc idles rough, idle is about 1200 rpm in neutral and 600 rpm in gear. If I drop the idle to 800 in neutral it stalls when put into gear. The engine runs better when im cruising and accelerating but dose no idle right.
Any ideals?
Old 03-29-2011, 08:50 PM
ratmaro's Avatar
the motor is bone stock including the cam.
Old 03-29-2011, 08:52 PM
Shaker455's Avatar
Any ideals?
If it's a Qjet carb then most likely the primary throttleshaft is worn and has sideplay and drawing in air and leaning the carb out.
We service alot here.
Old 03-29-2011, 09:00 PM
ratmaro's Avatar
Its a holley 4160, jets are 66 and power valve is 1 0 5. Every carb I put on this engine does not make any difference. still high idle in neutral and stalling in gear and rough idle.
Old 03-29-2011, 09:05 PM
Shaker455's Avatar
If every carb does the same thing then test for intake leaks.
Spray heavy amounts of soapy water right at the gasket area where the head meets the intake on both sides.
You may have to hold a piece of cardboard behind the spary bottle to block the air from the fan.
See if the puddles get sucked in and the rpms fall off.
Old 03-29-2011, 09:07 PM
ratmaro's Avatar
Just went out and tried this.... I used soapy water and carb cleaner... No vac leaks are found.
Old 03-29-2011, 09:11 PM
Shaker455's Avatar
Where in NY are you?
Old 03-29-2011, 09:13 PM
ratmaro's Avatar
Harpursville ny outside binghamton ny
Old 03-29-2011, 09:21 PM
Shaker455's Avatar
Okay,
How's it timmed?
How many turns out are the idle mix screws?
Old 03-29-2011, 09:24 PM
ratmaro's Avatar
My vacuum looks ok.. The needle is steady @ 15-16 in/hg seems a little low to me but dont know for a stock 305.
Old 03-29-2011, 09:25 PM
ratmaro's Avatar
Okay,
How's it timmed?
My mixture screws are out a 1-1/2 turns on each. My initial timing is set at 4*
Old 03-29-2011, 09:29 PM
Shaker455's Avatar
4 degrees with vac adv disconnected?...right?
Move the initinal up a bit like 12 degrees.
Whats total without vac adv?
Old 03-29-2011, 09:33 PM
ratmaro's Avatar
I really could not tell you... I dont have timing tape and my timing tab only goes to 8*. One thing I just remembered about is, in orde to get the car to idle I have to advance my distributor but when I do this the starter has problems restarting the engine once warmed up.
Old 03-29-2011, 10:23 PM
Shaker455's Avatar
That's okay you can borrow a dial back timming light from Autozone and you will not need anymore scale than what you have.
Old 03-29-2011, 11:50 PM
ratmaro's Avatar
Ill have to pick one up... But it seems anything I do with the distributor timing wise, It has no effect on the rough idle. If I turn the dizzy to achieve the highest rpm it still idles rough and stalls in gear. I got my engine to run at 900rpm in neutral and 600 in gear with vac advance unhooked. Hope this hleps a little.
Rough Idle, Dies in Gear klutchmaster427 Engine 13 07-02-2009 12:49 AM
1981 Gm 3.6 V6 Rough Idle And High Idle nomaddaddy Engine 1 11-15-2007 10:49 PM
rough idle, stalls in gear woedend Engine 4 04-15-2005 12:31 PM
Idle in Park is 1,800 RPM....Idle in gear in 900 RPM...Way too High. white66coupe Engine 11 09-10-2004 12:49 PM
Idle rough when placed into gear. BigMac Engine 5 03-28-2004 03:56 PM
