rough idle problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2005, 03:16 PM
rough idle problem
What's up everyone? My dad has a 94 jeep cherokee sport, inline 6 cylinder and he has been complaining of rough idle problems right before the engine blew. I replaced the engine for him and set the base timing last night but the engine still has a very lumpy idle. I checked the base timing with the timing light, I found the timing to be flickering between 26 to 20 degrees before 0. I redid the timing by finding tdc on #1 and yet the same result, not only that but the timing light doesnt give me a steady flicker it flickers and pauses in sync with the engine's missfiring. I removed the distributor cap and manually rotated the crankshaft watching the rotor rotate and as the timing mark on the crankshaft pulley reached 0 the rotor lines up with #1 on the cap which means mechanically the timing is set. I am lost any suggestions for troubleshooting would be nice the engine has a new cap,rotor, plugs and wires along with a new engine. It idles rough to the point where it wants to stall but then the idle picks up temporarily and prevents it from stalling.
Old 09-23-2005, 03:59 PM
docvette's Avatar
Wiki Edits: 12
Tune up kit
Doc here,
Looks like you have to go the tune up kit....
Not a cheap alternative... but then again that's Jeep...
You might try testing the voltages to the black box ignition and check it's grounds first..In fact run a separate ground from the box to the main grounding location on the block..
Be sure you have a constant 12 volts to the box and your Battery cables are clean and tight along with any secondary wires running to those cables..
Here is where you can get a tune up kit...(get ready for sticker shock..)
http://www.partsamerica.com/ProductL...or=Tune+Up+Kit
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Rough idle Yub350 Engine 1 12-07-2004 02:06 PM
Rough Idle ?? rb_quick Engine 3 03-09-2004 10:30 PM
rough idle and rev rakundig Engine 11 02-29-2004 08:36 AM
idle problem 56f100 Engine 2 10-31-2003 07:34 PM
rough idle! reggiesr Engine 6 01-29-2002 08:47 AM
