Rough surface opinion. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2005, 05:56 AM
New Member
Ugh, i should really get my sealer as smooth as glass before I lay down base.... Do you think clear will take care of this issue or will it stick out more? See picture
Old 10-14-2005, 06:08 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
I'd block it flat and re-base, generally clear magnifies problems
instead of hiding them.
Old 10-14-2005, 06:11 AM
New Member
done and done.
Old 10-14-2005, 07:20 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
That is way too much texture IMO.. Have you got your gun adjustment down?? From the pic, I think you need to play with the gun settings more too
Gun Settings
Great read here!!
Matthew
Old 10-27-2005, 06:18 AM
New Member
So I resanded the primer and resprayed the base. It looks alot better. Do you think so?
Old 10-27-2005, 06:31 AM
jcclark's Avatar
The Penny Pincher
It appears a lot better to me but pictures are hard to judge.
What did you do different this time?
Old 10-27-2005, 09:41 AM
New Member
Sanded the primer smoother. Last time I just glaced at it and thought it was smooth and didn't notice the small "canyons"
Old 10-27-2005, 06:42 PM
adtkart@aol.com
Are you trying for some type of texture. The primer should be sanded smooth. The texture of the primer will be carried through the base, unless you put alot of base on there to smooth it out. Generally I only use enough base to cover the primer, not smooth it out. Although you may get a smooth finish from the clear, you will likely be able to see the texture of the base.
what else in in wax and grease remover besides mineral spirits? Dubz Body - Exterior 47 06-19-2010 12:09 PM
wax and grease remover adrock430 Body - Exterior 14 07-30-2006 12:18 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
My paint goes on in droplets, rough surface. Help please Red5 Body - Exterior 19 10-14-2005 12:23 PM
my doors got stretched nomad57ry Body - Exterior 17 12-02-2004 06:51 AM
