Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roughing up clearcoat??
Old 03-08-2012, 05:33 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Hey Ron ,I remember this car ,You put 1/4s on and had a fitting problem with the decklid ...first off you dont want to use a sealer...if your DA sanding use 320-400 and if wet sanding 400 to sand the area you want color on if your doing a blend,and 600-800 on the rest thats to be cleared but blending is a little tough for someone without experiance and if I remember correctly your car is black so you can base the whole deck and not worry about blending ,it'll still match....one of the few advantages of using black any other color would need blending....
