Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - roughing up clearcoat??
Old 03-10-2012, 02:32 PM
rainbow lungs rainbow lungs is offline
Kustom Painter
Wet sand the entire piece with 800.
Do your spot repair. At least three coats of base.
Each coat of base go out 2-3 inches.
First coat 2-3 inches past where you see your sealer.
Next coat 2-3 past the fresh base and the last coat 2-3 past that.
Re-Clear the entire lid 3 coats.
Wet sand 1000 grit by hand with sponge pad. This get any dirt and orange peel if any in clear.
Then DA wet sand with 2000,3000, 4000 grit, this makes it almost shine
Now polish.
