-   -   roughing up clearcoat?? (http://www.hotrodders.com/forum/roughing-up-clearcoat-216255.html)
gto_ron 03-07-2012 07:47 PM
2 Attachment(s)
After repairing a small corner dent on my decklid I've sanded through the BC/CC and the epoxy primer sealer I used is showing. The rest of the decklid BC/CC is solid but I have to reshoot the entire piece to avoid the CC repair 'edge'. Do I need to rough up the rest of the CC surface before I seal it? If so what is recommended? Scotchbrite? 800 grit wet or dry?
thanks for any advice
Ron
TucsonJay 03-07-2012 08:16 PM
I use 600-800, or red scotchbrites.
tech69 03-07-2012 09:20 PM
I'd use 1000 for the clear area careful to not burn thru to the base, which may want to react since it's fresh. I'd also mist that base on there for the same reason.
jcclark 03-08-2012 06:00 AM
You'll get a much "straighter" finish if you sand the existing
clear with 600 or coarser. :pimp:
deadbodyman 03-08-2012 06:33 AM
Hey Ron ,I remember this car ,You put 1/4s on and had a fitting problem with the decklid ...first off you dont want to use a sealer...if your DA sanding use 320-400 and if wet sanding 400 to sand the area you want color on if your doing a blend,and 600-800 on the rest thats to be cleared but blending is a little tough for someone without experiance and if I remember correctly your car is black so you can base the whole deck and not worry about blending ,it'll still match....one of the few advantages of using black any other color would need blending....
gto_ron 03-08-2012 08:00 AM
1 Attachment(s)
Thanks to all!
I intend to reshoot both BCand CC over the entire decklid 'cause I'm not a good enough painter to blend it like the pros. I will use all your info and appreciate it.
DBMan, the quarters actually came out OK after some advice from the Forum and the car looks good but this decklid thing is pissing me off. Warm weather is almost here and my car is not ready.
regards
Ron
tech69 03-09-2012 09:25 AM
blending is easy and plus you have to worry about fresh solvents in your base reacting, unless you seal.
deadbodyman 03-09-2012 11:14 AM
12345678910
rainbow lungs 03-10-2012 03:32 PM
Wet sand the entire piece with 800.
Do your spot repair. At least three coats of base.
Each coat of base go out 2-3 inches.
First coat 2-3 inches past where you see your sealer.
Next coat 2-3 past the fresh base and the last coat 2-3 past that.
Re-Clear the entire lid 3 coats.
Wet sand 1000 grit by hand with sponge pad. This get any dirt and orange peel if any in clear.
Then DA wet sand with 2000,3000, 4000 grit, this makes it almost shine
Now polish.
Lungs
gto_ron 03-10-2012 05:54 PM
one more question
I'm following all your valuable advice, thanks !
I've always used Glasurit clear and had good results with this car and previous jobs. I'd like to try SPI Universal clear also. This decklid might be a great place to try it. Is there such a thing as CC mismatch? Should I stick with the same CC all over and play it safe?
regards
Ron
mitmaks 03-11-2012 11:31 AM
Use sanding paste with gray scotch brite
wayneooo 03-12-2012 04:04 AM
take it into a back alley tell it whos' the boss then rought it up a bit using a weapon of your choice :thumbup:
