round bar steel for shifter?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2013, 07:53 PM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hey.
Thinkin bout designing a shifter for my ih rat rod. Im goin semi theme so id like to go something big n round but not overkill. something i can heat and bend in a few places.
I see all kinds of steel rods and i want like a 48" piece but not sure wat kinda steel? Theres all kind of numbers n things.
any suggestions? Cold rolled? Tnx...HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 02-27-2013, 07:38 AM
Wiki Edits: 27
La Salle
I always liked the 37 La Salle shifter, about 3 ft long,Tapered from about 3/4 in to 5/16, came out of the top Rh side of the trans, very short throws. We have grabbed a couple big truck shifters from the wrecking yard, They are made from Alloy NOT hot rolled. Can be heated and bent., Cold rolled steel shaft material would work. Stainless shafting is more expensive and can be polished.
Old 02-27-2013, 08:03 AM
Sweet.
i dont want an overwhelming size but kinda big. Maybe 1 to 1.5 inch diameter???
Got any pics of that l asalle shifter? Tnx..RR
Old 02-27-2013, 11:21 AM
Wiki Edits: 27
google time images la salle transmission , long and tapered.
Old 02-27-2013, 03:04 PM
sedanbob's Avatar
Something a thick as 1 1/2" will be heavy, and if it's long enough, maybe heavy enough to come out of gear when you accelerate. I know it's not the same, but a buddy of mine had a column shift manual that he mounted a large square cube on. (it was drilled to look like a dice cube) Whenever he was driving in second gear (lever up), he had to hold the lever up so it wouldn't drop out of gear. Just a thought.
Old 02-27-2013, 07:48 PM
Ok.
thanks for the heads up. Ill do some checkin. RR
Old 02-27-2013, 11:57 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
How about a truck wrecking yard..there may be a suitable shifter handle..
Sam
Old 02-28-2013, 11:04 AM
46highboypu's Avatar
Last journal entry: More pin stripes
Here is a picture of the one I made for my '46. It's 1/2'' steel rod the I tacked a bolt to for mounting the piston knob. I thought it looked cool but was too heavy for my B&M shifter and would pull it down in gear. It's a shock when it does that!!
Name:	rod journal 105.jpg
leaf springs or 4 bar suspension? Is a 4 bar worth the expense? Hemi-Meadowbrook Suspension - Brakes - Steering 7 03-09-2011 07:18 AM
wish bone, panhard bar, track bar BigBlockT Suspension - Brakes - Steering 6 02-11-2010 10:25 AM
shifter tower, shifter rail and shift fork diagram needed! Chris Kemp Transmission - Rearend 0 02-12-2009 05:59 PM
Welding Stainless Steel to Hot Rolled Steel? Rambo_The_Dog General Rodding Tech 11 05-07-2007 10:05 AM
Top Bar of Front 4 Bar Link heyjude076 Suspension - Brakes - Steering 1 02-12-2007 09:10 AM
