round durablock with metal rod in it - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2012, 09:23 PM
put up or shut up
Wouldn't that be just perfect? Sometimes I have to use the durablock round block but am skeptical if I know the area isn't pretty straight already so I sometimes reach for my stiffer teardrop block, but has anyone out there put a rod thru a round durablock? Seems like a good idea for the skinny rectangle one too. man, I'm interested in finding out more. Anyone?
Old 05-31-2012, 09:36 PM
If I need an absolutely stiff round durablock I use PVC pipe. A 1/2" diameter is really good at getting into body curves with radii too small for the round durablock to fit completely into.
Old 05-31-2012, 10:56 PM
put up or shut up
yeah but that surface sounds kind of too hard and the paper won't sand the same. I dunno, that semi stiff dura block rubber is something I'm very fond of if the darn block can stay straight... but let's be honest, most or all those blocks tweak a little bit but not like the round flimsy one.
Old 06-01-2012, 07:13 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Just an idea is to take a piece of metal and wrap it with some sort of foam or other material to give the "give" that you want and use that as a block. Myself if I need a block of a particular shape I use a piece of pine board and carve it to the shape i need and apply some sticky back paper and sand away.. seems to work good on feature lines and such..
Sam
Durablock - Doubts Leandro Body - Exterior 12 10-15-2012 08:16 AM
sbc rod and main out of round zildjian4life218 Engine 2 01-13-2012 09:15 AM
Durablock set (biggest is 16") or a seperate 24"? JohnnyK81 Body - Exterior 2 01-25-2011 08:05 PM
video Street Rod Restoration - metal work Stomp Shear Bead Roller theacademy Hotrodding Basics 1 11-21-2010 08:07 AM
removing rod end with metal dust cover/spacer cboy Suspension - Brakes - Steering 3 01-24-2006 03:45 PM
