Round Port BBC heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2005, 05:49 PM
Camaro1994's Avatar
Well, let me first say hello to everyone. This is my first post since I came home from Iraq. My question is: Can you port the round intake ports to accomodate an oval intake. These heads came off of a truck motor which produces good torque. I know that these heads suck, but it is all my uncle has and can afford at this time. I myself would at least find a set of ovals and wish for the rectangle. I don't know if it has enough meat to cut for it to work. If not, where can I get an aftermarket intake for the round port heads. Any suggestions would be good. Thanks.
Jeff
Old 12-18-2005, 06:09 PM
BOBCRMAN@aol.com's Avatar
An oval port intake will fit on a round (small port) engine. The port size difference (mis match) should not make much difference performance wise.
You can only get so much air/fuel thru that small intake valve.
Old 12-19-2005, 07:22 PM
Camaro1994's Avatar
do you think that there is enough meat to port match to an oval gasket. the heads have 2.19 intake valves. I checked them with a micrometer
Old 12-19-2005, 09:02 PM
predator carb guru's Avatar
Mark Goulette
you have what's commonly called the "peanut port" heads, and were designed for heavy duty use, not performance. they do make great torque when matched with the right parts though. unfortuneately, there isn't enough meat there to enlarge them even to the standard size oval ports. although i'm not sure now, i know that the edelbrock performer intakes used to come with really small oval ports that matched up to the peanut port heads pretty good, and could be matched to the larger oval ports if needed. just haven't seen a new one in a few years, so i can't say for sure if they still make them like that or not
Old 12-20-2005, 10:07 AM
Weiand makes one "peanut port" manifold. Their #8017 Action Plus is basically what they call a "high rise" street dual plane manifold. It has a spread bore flange on it but you can easily adapt a square bore carb to this manifold.
It doesn't appear that Edelbrock offers a "peanut port" manifold. It's possible that Offenhauser might have one but I am not sure how you would find out since I have been unable to get my hands on a catalog and they don't seem to have a web site.
Old 01-28-2012, 09:34 PM
bigblockragtop's Avatar
old post did not realize
Old 01-28-2012, 10:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Since it's resurrected anyway, might as well add that there's an intake for the BBC PP heads- Weiand p/n 8122.
getting old iron heads to flow? (SBC) KNanthrup Engine 9 12-21-2005 05:06 PM
BBC rectangular port intake, oval port heads.. wildman926 Engine 14 10-14-2004 11:49 PM
Oval vs. Square Port Heads? Coleman396 Engine 9 07-22-2004 05:07 PM
BBC heads 65chevymike Engine 8 04-21-2004 02:25 PM
BBC Heads Triplany Engine 1 01-16-2004 08:26 AM
