rover 3.9 injection onto a 3.5 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Engine> Modern Electronic Engines
Old 04-13-2012, 05:12 AM
theg's Avatar
Hi all .
I have a 3.9 rover injected motor and the block has a cracked wall behind a liner . Its a common fault with these motors . I have a 3.5 motor which the 3.9 models are originally copied with bigger bores thus less meat in the cylinder walls which is the reason for the failure of so many 3.9 versions . The 3.5s never crack .
Id like to fit the 3.5 up with all the injection gear from the 3.9 ( its a direct fit)
My question is how do you think the mixtures etc etc would be with all the sensors calibrated for the 3.9 .
These injection systems are out of he early nineties .
The injection system is batch fired and does not have calibration calculated by 02sensors . Its all programmed into the computer at preset calibrations to meet the demand .
Theyre a basic injection system relying only on airflow meter , pedal position and air and water temperature sensors and road speed . No knock sensors .
Old 04-13-2012, 07:57 PM
LATECH's Avatar
Originally Posted by theg
Hi all .
Odd that it doesnt use 02 sensor feedback, but OK. Since it has a Mass air flow sensor it should work fine, at least I think it will.The MAF should keep the mixture correct as it measures the airflow , which is proportional to Cubic inches (or centimeters) .
It may be a tad rich, but if the original injectors for the 3.5 were a smaller GPH rating, you could swap to them to help keep fuel mix under control.
Without a feedback system of some kind you have no adaptive strategy to keep the A/F ratio at 14.7 to 1.
You could also lower the fuel pressure a bit, maybe, to keep the A/F ratio under control, unless it turns out OK from the get go. Chances are you will have to deal with a somewhat rich condition, but a little tweaking should get it running
well. JMHO
Recent Modern Electronic Engines posts with photos
rover metro convertable vikkibrady Introduce Yourself 2 03-21-2009 11:16 PM
range rover,yes,i said range rover wrencher1 Engine 0 09-03-2008 07:42 PM
Land Rover Motors trees Hotrodding Basics 2 03-17-2007 12:34 AM
rang rover hse DAILY Body - Exterior 1 02-08-2006 02:46 PM
buick215/rover 3.5 stevep Engine 2 03-01-2003 08:44 AM
