Rpm Air Gap Intake Onto A Stock 400sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2010, 08:55 PM
I have a 70 Chevy Caprice with a stock 400sbc and 2bbl carb/intake. I have sitting in the garage an Edelbrock RPM Air Gap intake, sumit racing 750cfm 4 bbl carb with electric choke, msd pro billet distributor and msd 6al ignition box and msd plug wire. The question I have is, would replacing the stock 2bbl intake/carb with the intake/carb I mentioned earlier flood my engine? Someone told me that it would make the motor run worse...which I highly doubt. The motor runs pretty good as it is right now, but would rather have a 4bbl carb. It's got about 130K on the original motor. I'm not very savy when it comes with engines, but an intake swap is pretty simple. I did a 327 2bbl to 4bbl intake swap and put an Edelbrock 600cfm carb on it and it ran fine. Just double checking. Thanks.
Old 04-19-2010, 09:10 PM
ericnova72's Avatar
More for Less Racer
It will work just fine. A carb won't "flood" an engine unless there is something wrong with it. Carbs don't "push" fuel into an engine, fuel is "drawn" out of a carb by the air flowing thru it. Put it on, your 400 will wake up.
Old 04-20-2010, 06:27 AM
That's what I thought, he was saying that I would need to upgrade the stock heads on there and I know that it shouldn't really matter if I left the stock heads on there and just changed the intake/combo.....thanks.
Stock 340 intake or Edelbrock Performer RPM daveh Engine 5 10-14-2009 09:51 AM
Torque link intake manifolds? xxllmm4 Engine 10 06-12-2009 07:20 AM
Valve covers hit Air Gap Intake - new crate 350 VEGA 3503508.5 Engine 18 08-07-2007 10:11 AM
Edlebrock Air Gap Intake vs. Holley Contender 72Nova383 Engine 5 10-26-2004 08:56 AM
Stock eliminator 78 monte Engine 5 01-02-2003 05:10 AM
