RPM/Airgap extra cooling bosses - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2005, 09:54 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I have an RPM/Airgap. I want to take advantage of the extra cooling potential of tying the front and rear cooling bosses together. I will require a Tee in the passenger side front boss for the heater hose.
The problem. The rear bosses are 1/2 in NPT and the front bosses are 3/4 in NPT. The 3/4 inch AN fittings cross to a #10 hose and the 1/2 inch AN fittings cross into a #8 hose.
I have also looked into using brass fittings. No matter what combination I use. I have to buy alot of adapters and/or bushings that will make the project look tacky.
With brass I have to use 5/8 inch rubber hose (tacky). With AN I could drop down to #8 braided but would send the project into the 100 + dollar range.
Anybody ever took advantage of this feature and how did you plumb it?
Old 04-02-2005, 10:27 PM
coldknock's Avatar
Rent a 3/4" pipe thread tap.
Larry
Old 04-02-2005, 10:37 PM
bracketeer's Avatar
489 Lemans
thought of that
I would cut too deep into the boss and weaken it.
Old 04-02-2005, 11:20 PM
coldknock's Avatar
Dang.
Try a reducer bushing in the front openings. Even if it was smaller than you needed it could be re-tapped to 1/2".
Larry
Old 04-03-2005, 12:14 AM
bracketeer's Avatar
489 Lemans
I found it.
Jegs carries a kit. It attaches to a plate under the thermostat. You don't have to hook into the heater bosses. I have a thermo housing with two 1/2" sensor holes. I will plum from the rear bosses to the housing. Can do it pretty cheap.
Need some cooling suggestions f355bird Engine 14 04-04-2006 05:04 PM
What Is Reverse Flow Cooling? STATUTORY GRAPE Engine 9 05-19-2004 10:50 PM
Enough Cooling? jamnut Engine 3 07-18-2003 01:13 AM
-AN fittings on transmission cooling lines jamnut Transmission - Rearend 3 07-14-2003 11:07 AM
Cooling Help Please. F-1Rodder Engine 2 09-06-2002 09:18 AM
