RPM question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2006, 11:47 AM
RPM question
Hi. I just discovered this site and have a question. I just purchased a 1973 Nova with a 383 stroker tied to a 700R4 tranny that is supposed to generate 450 HP at the crank. I would like to know what a safe RPM limit would be for this motor. More information on the motor is below:
383 Stroker w/ 4 bolt main
World SR heads 67 cc ~ 10:1 compression
Comp. Cams 268 degree high energy w/ roller rockers
Pete Jackson noisy gear drive
Edelbrock 3701 Performer intake manifold
Summit blueprinted HEI distributor w/ Accel wires
Q-Jet 4 barrel carburetor built by Jet Performance Products
Hedman coated headers w/ A.I.R.
Flowmaster 2 exhaust
Big block 4 row radiator
Thanks
Old 10-17-2006, 12:24 PM
DoubleVision's Avatar
Camshaft and valvetrain dictates when it`ll run out of breath. With that cam it`s just right for a high torque street machine, i`m sure it`s a blast to drive.
The rpm band of that cam if I remember correctly is to about 5500, however, the rest of the valve train, such as the springs and etc. will all play a role as well. if the valve train was set up to match the cam, it`ll be fine to 5500.
Old 10-17-2006, 12:38 PM
Yeah, it's a blast! Everything I can see was done right. But since I don't know about all of the internal workings, I think I'll set the redline on the tach at 5000.
Here's the rest of the fun stuff!
TCI converter
B & M Megashifter
Balanced driveshaft
8.5 10 bolt
Richmond 4:10 gears
HD GM posi-traction
HD Dutchman 30 spline axles w/ wheel studs
3/8 stainless fuel line
Holley fuel pump
Stainless Steel power disc brake system
Subframe connectors (Competition Eng.)
Big block springs (front)
HD springs (rear)
Poly body mounts
Fast ratio Steering box built by AGR Steering
Front sway bar (1.125) by PST
Rear sway bar (.875) by PST
Old 10-17-2006, 01:30 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Also, another deciding factor is the ignition system..
a Stock HEI is good to about 5500 RPM.
A Performance HEI is good to about 8500 RPM.
A CDS Ignition is good to right about 10,000 RPM.
Exceeding those points for each makes the spark look like a continual blue flame to combustion..(no rise/fall Time) and can hamper firing of the cylinders.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-17-2006, 01:51 PM
With the cam and the intake your gonna run out of breath at 5500. If your bottom end is cast you could run it up to 6k on occasion and be ok. Set it at 5500 and go
blower idle rpm problem Ratoflic Engine 7 12-01-2008 03:31 AM
Belt Keeps Flying Off at High RPM - Why? leejoy Engine 67 02-20-2008 11:12 PM
351 windsor running rich ???? ve3ham Engine 19 08-08-2005 12:48 PM
what rpm would you suggest 53LEDSLED Engine 13 06-03-2005 10:34 AM
question about cams hotrod66_57 Engine 7 07-20-2004 08:59 AM
