You don't need long rods to rpm a motor. You don't need high or low DCR to rpm a motor Referring to DCR, you figure this when you're planning the motor, before you ever buy a part. It is DCR that determines the fuel you will have to use to prevent detonation. Another way of looking at DCR is cylinder pressure. If you're gonna make a lot of cylinder pressure (high DCR), then you will need to use a fuel that will be resistant to detonation such as racing gasoline or alcohol. If you use a lower cylinder pressure (low DCR), the motor may run on unleaded regular gasoline without a whimper. Problem is, there are many different calculators to figure DCR and all of them are a little different. You need to zero in on one calculator and use it all the time so that you know the results are valid. I have used the calc on Keith Black Pistons site for years and know that for a pump gas motor, I will want somewhere between 8.0:1 and 8.5:1 DCR. I adjust it by altering the static compression ratio (SCR) and the intake closing point of the camshaft. |
It really comes down to, "how high is high rpm?" |
Tech
Really glad to see you. More to come I hope. PatM |
^^^^ X2 Tech
Midnight Sun Street Rod Association |
Birkey,what do you call "high" rpm? 5500 rpm and an old v-8 is not a problem with little more than a cam and kit,by the time you reach 7500 rpm(still using an old v-8) you have incorporated roller rockers,forged pistons,steel crank,solid lifter cam,better induction and exhaust. when you go from 8-9,000 rpm,you have the best of everything,you have had to do a piston speed calulation(pistons have a limit to how many feet per second before coming apart), very special cam grinds,extreme valve spring pressures,extreme lengths to stabilize rocker geometry,custom induction and exhaust that is very specific to application. after 9,000 rpm you better know some engineering basics and metalurgy basics and understand flame propagation/combustion chamber design and fuel burn speeds. at this point you need extremely deep pockets for the exotic (short lived) parts
| The Following User Says Thank You to vinniekq2 For This Useful Post: | ||
techinspector1 (10-06-2012) | ||
As a matter of fact I do. What is the difference in timing, between a low compression motor (8:1) vs a high compression motor (10:1) obviously there is a change in timing when compression is changed. I just want to get an idea of the range.
I knoow there are many factors that change timing. But bare with me and say you run 91 octane. I'm not.looking for a specific answer just wondering how big the gap is. Is it just a few degrees or much more?
also have to consider combustion chamber shape,camshaft profile,fuel metering system,ignition system controller,,, look up the new mazda economy engine that burns gasoline and has 14:1 compression.lots of high tech euro engines have 12:1 cr.,,,cooling system makes a difference,metal used in cylinder head,like aluminum or cast iron
Demon Fuel Systems Click on the tabs "Performance Cam Profile" and "Radical Cam Profile" to see the entire range of duration/spark timing..... |
| 5.7 Litre (350 CID) New Marine Engine 275 hp @ 4800 RPM / 340 lb-ft @ 3200 RPM (4bbl) | bramhall01 | Engine | 2 | 06-13-2012 04:43 AM |
| 305 max rpm/reasonable rpm range etc.: | against all odds | Engine | 1 | 10-11-2011 09:11 PM |
| Edelbrock Vortec RPM or Air RPM intake | Hanks56Chevy | Engine | 8 | 07-19-2010 09:25 AM |
| Performer RPM to RPM Air Gap Swap-350 chev | corvette77 | Engine | 3 | 09-01-2008 08:23 PM |
| Edelbrock RPM intake or RPM Air Gap? | KeithB123 | Engine | 1 | 02-18-2004 08:08 PM |
