RPMs and mileage - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2006, 03:34 PM
strummin67's Avatar
Violating consensual reality
Last journal entry: It tows!
RPMs and mileage
Hello. I have a stock 194 6 in a 3:36 geared Nova wagon. I have added a T5 tranny and found 4th (1:1) RPMs at 2900 at 65MPH. OD brings the RPMs to 2088 at 65MPH. I've found this to be too low and bad for mileage. Anything over 3000 RPMS also cuts into mileage. Lately I have been playing with different OD and rear gear ratios on a calculator and changing just the OD from a .72 to a .86 brings the RPMs to 2494 at 65. In addition I tried putting 60 series tires on and changing the rear gears to 3:55s getting 2813. Not much of a difference from the original 1:1 number. Do you think my engine can operate at or just under 2500 and not lose mileage or am I better off sticking closer to 2900 Thanks.
Strummin
Old 07-27-2006, 03:40 PM
cabowabo's Avatar
big Q
uh hmmmm
sit down shut up and drive
Old 07-27-2006, 03:54 PM
strummin67's Avatar
This is a daily driven car so I think you can appreciate my concern.
Strummin
Old 07-27-2006, 04:51 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
i try and gear for the peak torque at cruise..that seems to work about the best...I do suppose your engine is about at its peak torque at around 2900-3000..
Sam
Old 07-27-2006, 05:35 PM
strummin67's Avatar
According to Nova Resource max torque for these engines was 177 ft lbs at 2400 RPMs.
Old 07-27-2006, 06:17 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What kind of mileage are you getting?
Old 07-28-2006, 12:19 AM
strummin67's Avatar
Based on what I got before the tranny swap 15 City 19 Hwy.
Strummin
Old 07-28-2006, 05:38 AM
Lost in the 60's
Wiki Edits: 4
I just wondered. I bought a Nova new in 67 , it was a 6 cyl. with automatic trans.....It got 18-20.
Old 07-28-2006, 08:29 AM
strummin67's Avatar
I'm probably alright where I am. I just think I can do better.
Strummin
Old 07-28-2006, 10:55 AM
larryblack's Avatar
Certified Lead Foot
Strummin
Try and remove some of the lead from your right foot. Using less downward force would help too. LOL
Seriously, trying to get the "prefect" gear and tire combo can be a crap-shoot at best.
I like using a vacuum gauge. While cruzin', running with the highest vacuum readings usually gets the bestest mileage.
Old 07-28-2006, 11:52 AM
strummin67's Avatar
I do drive conservatively otherwise I would not be able to afford to drive the car every day like I do. I want to keep a 6 in the car because it's different. So would it make sense to keep my rebuilt 194 and play with the gears or go with a 250? Either way I'll be spending about $1800.
Strummin
Old 07-28-2006, 12:07 PM
Lost in the 60's
Wiki Edits: 4
The 67 that I had had a 250 6 cyl. in it. You need some more cubes...the 6 you got has to labor harder than a 250 would.
Old 07-29-2006, 12:26 AM
strummin67's Avatar
Hey everyone. Thanks for your advice so far.
Strummin
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
axle swap jose a roman jr Transmission - Rearend 3 10-24-2005 07:18 AM
Gas mileage vs. gears jcp123 Transmission - Rearend 9 05-31-2004 08:28 PM
