Okay so I'm in a dilemna. I can't find an off the shelf gasket that fits my needs. So my options are to modify an available gasket to work (just add bolt holes is the correct location) or I could install it with no gasket and just rtv.
Its a sbc, vortec heads non vortec intake that has been redrilled, edged are just too short to cover upper edge of coolant crossover on the gasket but it covers the actual port on the head. Thinking of maybe modifying a small race port gasket since the coolant crossover port is smaller. The vortec gasket I tried in the hard plastic one with the red o-ring from felpro. 90131. The one I may modify is 1206.
Modifying another gasket is pretty straight forward with an xacto knife. The 1206's are pretty thin around the top of the ports, not sure it gives you much wiggle room. While I prefer FelPro's I find that Mr Gasket gaskets lend themselves better to cutting than FelPro's. They tend to be a little softer.
I may go with 136G gasket from Mr. Gasket, or I may just pick up a sheet of gasket material and cut the whole thing myself, either way it looks like its a no go for just RTV.
I was thinking about that the other day, rather then using exacto knife to cut isn't there some sort of sharp edge punches a guy could use that would leave nice round holes?
a section of pipe with the outer edge ground to a sharp edge.
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
