Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rtv sealer on gasket pan?
Old 01-28-2011, 03:33 AM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
Originally Posted by BOBCRMAN@aol.com
I usually use sealer on the block side/corners. Makes for cleaner pan removal, if needed, in the future..
I believe he was talking about the tranny pan.
Use the sealer between the gasket and the pan. None on the tranny side of the gasket. Let it set up for a couple of hours so it doesn't squish inside of the tranny when you bolt up the pan.
