rtv silicone in rear main cap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2005, 05:09 PM
This my 1st motor build, its a 92 ford 5.0...
Do I need to put silicone in between the rear main cap and the block? It sounds like something I could mess up really easily.
Does anyone have advice on installing a one piece rear main seal? Neither of the books I have go into detail on one piece rear main seal installation. Any other advice is always appreciated. Thanks, John
Old 08-21-2005, 05:23 PM
347mustang's Avatar
no..maybe just a little yellow glue.to hold it in place...than i usally run a small bead over the top of the seal before i install the oil pan,,,.just a little...not a big blop....and a little more in the corners where the pan gaskets meets the front and rear main seal...just dont go crazy ..i have always done this and have never had a leak or a probelm...
Old 08-21-2005, 07:39 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
YEEEEEEHHHAAWWWW
Absolutely use a one piece rubber pan gasket..$ 35. If you can't afford to do it right the first time, think how much aggrivation it will be when you do it again.
As for installing the one piece seal.... don't bend it when you tap it in... use something to spread out the pressure..... lube the crankshaft seal surface and the seal with assembly lube before installation. You don't want it to be dry at first start up. You might check with a Ford Mech. or a GOOD machine shop. They usually share advice to novice hot rodders.
please check out www.readershotrods.com drag cars/georges
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Main cap problem on NEW motor,,,,,,what the @*!$& do I do now????? STATUTORY GRAPE Engine 13 06-26-2005 09:15 PM
SBC Block Questions Mustangsaly Engine 14 06-23-2005 10:14 AM
Question on SBC with 1 piece rear main seal Houman SS '70 Engine 6 05-02-2005 11:18 PM
Main cap girdle shagginwagonvic Engine 4 11-19-2003 10:08 PM
