RTV for Vortec intake gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2011, 12:01 PM
With the torque so low,11lbs for the vortec heads intake manifold, what is the best RTV silicone to use? Thanks
Old 01-03-2011, 12:16 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Permatex RTV ultra black is what I have used many times, no issues, just make sure everything is very clean and that you drop the intake as straight down as possible after applying a good thick bead end rails, don't use any cork or rubber on these end rails, a stud or two will can help line up the intake, follow the torx sequence
Not sure what vortec inatke gaskets you have but the felpro MS98000T set contains the best ones IMO.
Old 01-03-2011, 01:47 PM
King of my Man-cave.
You have to use a locking compound on the threads of the bolts to prevent them from loosening up.
tom
Old 01-04-2011, 11:09 AM
Locking compound
Tom, would blue locktite be ok as a thread sealant or is there something you would prefer. Thanks.
Old 01-04-2011, 01:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
All that's needed is a thread sealer to prevent oil from wicking up the threads and staining the intake manifold. If the threads and bolts are spotless, you can use RTV. Or Permatex #2, Permatex Form a Gasket #80018, teflon pipe thread dope, etc.
are sbc 350 gaskets sets the same despite the year and/or if its a vortec??? Rod stalker Engine 4 08-17-2009 05:44 PM
OE Vortec intake gaskets with aftermarket heads/intake? 04SilveradoMykk Engine 3 05-17-2009 11:07 PM
Vortec valve cover gaskets Red West Engine 1 09-15-2008 07:49 PM
Vortec Head and Intake Gaskets Chevy21 Engine 2 05-26-2005 03:04 PM
Intake manifold gaskets for alum. heads and intake mustang66maniac Engine 6 02-20-2004 11:19 AM
