We're winning the case!
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 01-15-2006, 12:35 AM
tiresmoke55's Avatar
tiresmoke55 tiresmoke55 is offline
PO-BOYS-TOYS!!
rubber brake line's for a 55 chevy
hello, am changing drum's to disc in the front of my 55. am using 69 camaro rotors and 80 Chevy calibers, I need to know what is the best rubber brake line's to use since 55 Chevy factory line's are too short? thanks
Old 01-15-2006, 03:43 AM
curtis73's Avatar
curtis73 curtis73 is offline
Hates liver, but loves Jmark
curtis73's barnstar
Wiki editor
Wiki Edits: 16
I would investigate the lengths of all possible hoses from what you have. Look up the hoses from the car that uses those spindles, the hoses from the application of the calipers (which were used in TONS of GM cars) and a few others. Just choose the hose that gives you the right length with the right fittings on either end.
I ended up using some truck hoses on my custom setup. I determined the length by jacking the car up so the suspension was at full droop, and turned the wheels left and right to make sure I had enough, but no extra that would get in the way when the suspension was compressed.
Old 01-15-2006, 04:43 AM
PO-BOYS-TOYS!!
rubber lines
I have heard that you can use truck rubber lines.. what am really looking for is the lines they send you in those disc brake kits for 55-57. in the kit it uses 69 camaro rotor and mulibu calipers which i already have, the only thing i dont have are the lines...if i use muibu line's they are about 21/2 inch's short... thanks dave
Old 01-15-2006, 09:38 AM
HUH?'s Avatar
HUH? HUH? is offline
Tri 5 Disk Brake Hoses
Give one of these a try:
NAPA part # 36845
I found these listed for use with 2" drop spindles
Bendix-77225
Wagner-F98912
Raybestos-BH36845
EIS-SP5753
I am in the information gathering stage of my disk brake conversion, so I cannot verify these numbers.
http://www.picturetrail.com/yelrah_dave
Old 01-15-2006, 01:04 PM
PO-BOYS-TOYS!!
rubber lines
Thanks for the part number's Ill go to the part store and check out those line's. I wonder if they will still work with my spindles because am using the original 1's on my car am not going to put the drop spindles on it..I bought a set of disc plates that will keep my original ride height.."headers drag sometimes as it is thanks for the help Dave
Old 01-16-2006, 07:13 AM
HUH?'s Avatar
Stock spindle hose
The NAPA hose number is supposed to fit stock spindles.
The other four were for drop spindles.
Let us know if any of them work and good luck on your project.
Old 01-16-2006, 08:26 PM
PO-BOYS-TOYS!!
rubber lines
Well i went to the part store and ordered 2 hose's #36845..they wont be in until a few days but they showed me a pic'c of the fitting on the end and it don't look like it will bolt to a Malibu caliper? Am really not for sure yet but ill give it a try..the length look like it will work but not the fitting. Something i think was funny is any time i go to a part store and being that am only 24 yrs old buying parts for a 55 Chevy they look at me funny and say, so you like the old cars, i figured you wanted some Honda parts..
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "rubber brake line's for a 55 chevy"
55 chevy disc brake set up? tiresmoke55 Suspension - Brakes - Steering 4 01-15-2006 11:19 AM
trying to build a 55 chevy tiresmoke55 Introduce Yourself 3 01-13-2006 07:11 PM
Stainless Steel Brake Lines Blazin72 Suspension - Brakes - Steering 2 10-27-2005 10:45 PM
brake lines too short after suspension rebuild FiveFeezy Suspension - Brakes - Steering 4 03-10-2004 09:25 PM
