Rubber burning smell - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2011, 05:55 PM
mitmaks's Avatar
Last journal entry: Grille
My mom's car has a rubber burning smell coming from rear right wheel. I lifted it up and inspected it and wheel moves freely. I took brakes apart, greased up sliding pins, back of brake pads, sliders, etc
What could be problem?
Old 01-22-2011, 08:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If the brake shoes aren't hanging up, is she a 'brakelight driver', keeping a foot hovering and ultimately resting on the brake pedal? I see it all the time. Just a thought.
Old 01-22-2011, 08:15 PM
mitmaks's Avatar
But it's just that one wheel. I might try caliper rebuild if this doesn't fix issue.
Old 01-22-2011, 08:18 PM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
did a rubber exhaust hanger break, and is now laying on the exhaust?
or exhaust now touching the spare tire?
Old 01-22-2011, 08:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
No kinks in that wheels brake line, holding pressure for a while? Any fresh rub marks on the inside of the tire?
Old 01-22-2011, 08:21 PM
mitmaks's Avatar
Could it be bad wheel bearing?
Old 01-22-2011, 08:24 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I wouldn't think wheel bearing with a rubber smell. The only rubber there might be the seal, depending on the vehicle, it only rides lightly on the axle shaft if anywhere.
I guess if it was a sealed bearing pack, ala 9" Ford housing ends, it may have some rubber sealer or "O" ring, but you'd hear it and have leaks if it was that bad.
What kind of vehicle?
Old 01-22-2011, 08:27 PM
& matts38chev
does it smell like burnig rubber or nasty old hot gear oil?
hold on, hold on, what kind of car is it?
Old 01-22-2011, 08:54 PM
mitmaks's Avatar
96 lexus es300
Old 01-22-2011, 09:34 PM
& matts38chev
now im back to this
Old 01-22-2011, 09:51 PM
sqzbox's Avatar
My pipes are my music
Tell mama to quit doing burn outs!
Old 01-23-2011, 07:04 AM
pepi's Avatar
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
That was my first thought also ......
Old 01-23-2011, 01:49 PM
T-bucket23's Avatar
Wiki Edits: 26
Hot brakes have a very unique smell and it is not anything like burning rubber. I would look else where, as someone else mentioned maybe something on the exhaust. Also look for shinny spots, maybe you have a tire rub on a body part or something else
Chet
Old 01-23-2011, 01:53 PM
mitmaks's Avatar
That's what I thought. However after taking it for a test drive I did smell faint smell of burning rubber from that wheel well. Brake pads are Hawk HPS and never had problem since I've installed them on the car last year.
Old 01-23-2011, 02:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If it has a caliper hanging up i have seen and smelled the rubber burning before from it , The caliper will hang and get hot and start to burn out the rubber in the caliper around the piston. JMO
Exspecially if your mom has been riding the brakes and or has had to slam the brakes on can cause the brakes to hang and get hot also. Again JMO.
Cole
Come smell the new guy!!!! bigjim13 Introduce Yourself 5 06-08-2007 09:59 PM
Oil smell kc_ksom Engine 6 11-13-2005 07:01 PM
What's that smell? jcclark Body - Exterior 3 11-09-2005 03:43 PM
smell of oil? adam15425 Engine 5 09-14-2004 10:49 PM
Dog Smell! Mrfixmaster Interior 21 02-04-2004 09:28 AM
