rubber hose to modulator ok? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2004, 02:39 PM
unstable's Avatar
Murderator
Last journal entry: Brackets, Stories and the future
Hello again everyone.
About a week and a half ago me and dear old dad started putting the new components in the 77 Chevy 3/4 I gave to him. He bought a new motor, trans and transfer case. We scoured what we could off of an 85 Truck and had some stuff left over on the 77.
It's coming together albeit slow.
The vacuum tube going down to the modulator is pretty nasty. Wondering, for simplicity sake...could we run rubber hose instead of a steel line?
I'm going to have more questions later...as we progress.
Old 08-02-2004, 02:58 PM
steel line
you want the sleel line in there you don't want that rubber line deteriorating and coming apart or sucking closed. run steel line.
Jesse
Old 08-04-2004, 08:14 AM
k2mooch's Avatar
I use steel brake line and rubber at the ends.
MoocH
Old 08-04-2004, 08:01 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
A common failure of the use of "all" rubber hose is the side wall of the hose.
As mentioned the vacuum hose will collapse and flex under vacuum increase decrease. I've seen many hoses with splits in the long hose from the flexing
