-   -   Rubber transmission lines? (http://www.hotrodders.com/forum/rubber-transmission-lines-100804.html)
HotRodMan 10-21-2006 09:30 PM
I am installing a new aftermarket radiator in a 65 Plymouth. The old radiator had the transmission lines come directly into the bottom of the radiator. My new radiator is a cross flow and has the entry point for the transmission lines on the driver's side.
The easiest way to re-direct the lines would be to connect the radiator and the old cooling lines with rubber transmission hose and clamps.
Is there anything wrong with following this procedure?
poncho62 10-21-2006 09:37 PM
You would be better off to make new steel lines, or add to the old ones with compression fittings etc. Steel lines make for a cleaner looking instalation.........Rubber lines look more tacky and could rupture more easilly................there is a bit of pressure in tranny lines.
