Rubber transmission lines? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2006, 09:30 PM
I am installing a new aftermarket radiator in a 65 Plymouth. The old radiator had the transmission lines come directly into the bottom of the radiator. My new radiator is a cross flow and has the entry point for the transmission lines on the driver's side.
The easiest way to re-direct the lines would be to connect the radiator and the old cooling lines with rubber transmission hose and clamps.
Is there anything wrong with following this procedure?
Old 10-21-2006, 09:37 PM
poncho62's Avatar
Wiki Edits: 5
You would be better off to make new steel lines, or add to the old ones with compression fittings etc. Steel lines make for a cleaner looking instalation.........Rubber lines look more tacky and could rupture more easilly................there is a bit of pressure in tranny lines.
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Engine and transmission mounts cucumber1949 Hotrodding Basics 1 08-07-2005 08:15 PM
Transmission cooling lines and fittings... wickster Transmission - Rearend 4 03-31-2005 05:55 PM
83 Z28 Transmission - YIKES! crandaz28 Transmission - Rearend 4 11-25-2003 07:43 AM
Dressing up rubber under the hood. reluctant_paladin Engine 2 05-17-2003 08:33 PM
