I am installing a new aftermarket radiator in a 65 Plymouth. The old radiator had the transmission lines come directly into the bottom of the radiator. My new radiator is a cross flow and has the entry point for the transmission lines on the driver's side.
The easiest way to re-direct the lines would be to connect the radiator and the old cooling lines with rubber transmission hose and clamps.
Is there anything wrong with following this procedure?
