Rubbing clear coats. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2008, 06:37 AM
I finished clear coating my car and I waited one week for the coat to dry up. Then I wet sanded it with 1500 grit and 2000 grit. Thinking all the surfaces were ready for rubbing, I rubbed it without problem except for the left front fender. It did not shine like all the other parts of the car. The fender glows dull and when touched by hand, it leaves hazy print marks on the surface. I did another round of rubbing it but the problem is still there. Can you help me what caused it and how can I fix it?
Old 03-28-2008, 06:52 AM
cyclopsblown34's Avatar
Colorsanding painter
Is there a possibility you sanded off all the clear on that fender? That's what it sounds like to me.
Old 03-28-2008, 10:50 AM
Is there paint on your compound pad?
Are you using an electric buffer? what type?
Old 03-28-2008, 07:11 PM
Countilaw's Avatar
Cox Custom Cars
sounds like he sanded into the basecoat to me too.
It's very hard to diagnose a problem without seeing it. So photos would help and would a step by step on how you painted the car.
Did you mix all you paint at the same time? or mix each cup before you shot it on the car?
Frank
Old 03-28-2008, 10:04 PM
lets cut it up's Avatar
Did you use a gravity feed gun and mix the clear in the cup and start on that fender? If so you have un-catalyzed clear on the first few passes of that fender.
Old 04-04-2008, 11:02 PM
sanding clear coats
Thanks for replying. My pad is clean and yes I'm using an electric buffer. It's a black and decker with variable speed - 1200 to 3000 rpm. I buffed the car at 1600 to 2000 rpm. I will appreciate any advice you can give me to correct the problem. Thanks.
Old 04-07-2008, 12:09 PM
If you can take a damp rag or a piece of 2000 grit and sand that spot. One pass will tell you if you blasted through the clear. If the residue is whitish, you should be safe(unless the paint is white), If the residue is body color, you blasted through the clear. Other than that, the post about uncatalyzed clear makes me wonder.
Good luck,
Chip.
Old 04-08-2008, 10:25 PM
is there a fix for uncatalyzed clear besides repainting?
last coats of clear [sikens] jim r Body - Exterior 6 05-05-2007 06:16 PM
Time between coats of clear redboat Body - Exterior 6 02-12-2007 02:16 PM
final sanding with 2 coats of clear? Saddlebacks Body - Exterior 3 10-08-2006 08:15 PM
time between coats of clear?? alteredpilot Body - Exterior 28 08-03-2005 02:50 PM
Time between Clear coats TurboS10 Body - Exterior 11 11-23-2002 04:55 AM
