Ruh Roh Raggy
I'm posting this here 'cuz I didn't want to hijack the "clearcoat not flowing well" thread. Sorry if this should be in different forum
MARTINSR - you posted that a 10 cfm wasn't enough air to paint with. I just put in a husky 60 gallon with 10.3 cfm at 90 psi. Am I screwed? I'm not planning on putting on base and clear, just shooting epoxy primer after doing body work. thanks for the help! |
i think u will be fine for smaller repairs, no painting whole car at once
Thats the same exact compressor I have, I just got it, I painted my 87 dodge ram it was fine, kept up good, I used the harbor freight gun hvlp
[QUOTE=modas]
MARTINSR - you posted that a 10 cfm wasn't enough air to paint with. I just put in a husky 60 gallon with 10.3 cfm at 90 psi. Am I screwed? QUOTE] At what psi is he saying 10 scfm? Certainly 10.3 scfm at 90psi is quite sufficient for spray painting. Vince |
My compressor is only 8 CFM at 90 PSI, but with the hvlp
gun I use at 30 PSI my compressor hardly runs. Like the others said, check your cfm requirements of your gun. At the lower PSI's you use a lot less air. 10 CFM @ 90 is a lot considering a gun spraying at less than half the PSI. Now air sanders is a different matter, my compressor can't keep up with some of those. |
