Rumble in 3rd member? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2012, 07:44 PM
Had 411 gears put in my 9" rear end. I now have a noise, a rumble and vibration, not under power or completely off the gas pedal. The noise is in the neutral spot when not accelerating or decelerating. I don't remember having this noise before I changed the gears. I suppose there is a possibility that it is a u-joint or an out of balance drive line. I tend to think it is in the rear end, because the drive line and u-joints are new as of approx 3200 miles ago.
Any ideas on what and how to check this?
Many thanks!!!
Bill
Old 06-10-2012, 09:00 AM
The Flyin Wop's Avatar
Paisano
Last wiki edit: How to remove an ignition key lock
Wiki Edits: 4
Having worked on Ford rear for many moons,usually if a "rumble" type noise means soimething is loose or has a crack in it making something move like a cracked carrier support cap.It could be possibly a pinion nut was not properly tighted down,caps,too much backlash or not enough.
A whine woulf indicate a bearing.Did the use the same bearings? Maybe they tighted the pinion down to tight.
That's a guideline,without bein there to hear it,could be anything Dude
Paisano
Old 06-10-2012, 03:22 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Many thanks!!!
Bill
The driving condition you are hearing the noise (the neutral spot when not accelerating or decelerating) is called "float". It sounds like a pinion bearing preload problem to me.
You can check the driveshaft phasing to be sure they didn't put it on wrong.
Old 06-11-2012, 01:30 PM
Finally figured this out. My pinion angle was too severe about 6 degrees out. Put a 4 degree wedge to tip the pinion up. Still had the noise and rumble but only about 30% of original. Rear u joint was bad. Only about 2k miles but at the severe angle it apparently ate the thing. New u joint and it's nice and quiet.
Thanks for the help!!
Bill
3rd member identification allclassicsbefore70 Transmission - Rearend 2 07-12-2011 02:31 PM
Ford 9 Inch 3rd Member Identification My79Ford400ciF1504x4 Transmission - Rearend 2 10-08-2010 06:51 AM
9" 3rd member packaging Fergusonic Transmission - Rearend 1 12-11-2007 11:08 AM
'58 Chevy 3rd member Quick 58 Transmission - Rearend 0 10-18-2007 05:55 PM
Rear 3rd member swap 53Z Transmission - Rearend 4 10-12-2002 03:05 PM
