rundown on setting up valve lash - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2010, 11:34 AM
ok so i just put my new rebuilt motor in the car, but im not 100% the proper way to put the pushrods in and setup valve lash for camshaft breakin. Anybody have a quick rundown for me, i would greatly appreciate it! thanks
Old 09-07-2010, 02:00 PM
Do you have hydraulic or solid lifters?
Old 09-07-2010, 02:28 PM
techinspector1's Avatar
Wiki Edits: 326
Here's the procedure for hydraulics....
http://www.crankshaftcoalition.com/w...MENT_SBC_/_BBC
Old 09-07-2010, 02:29 PM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Assuming they're hydraulic...
Rotate the engine until the exhaust lifter for the #1 piston (front driver's side) rises and falls. Keep rotating the engine until the intake lifter rises and falls. Both lifters for that cylinder will be riding on the flat surface of the cam lobe.
Loosen the rocker arm nut until you can move the pushrod up and down and it spins freely. Now slowly tighten the rocker arm nut while spinning the pushrod back and forth between your index finger and thumb. Tighten it until you feel just a slight resistance. Be sure your socket wrench isn't resting on the rocker arm or you may get a false reading. Try and move the pushrod up and down to be sure their is no play. Recheck the resistance on the pushrod again by spinning it and tighten as necessary to get that slight resistance back. You will now be at zero lash.
Once at zero lash, orientate your socket wrench at the 12 o' clock position. Now give the rocker arm nut one half turn. You handle should now be at 6 o' clock. Do that to both that exhaust and intake rocker arms and you are set for that cylinder.
Move to the next piston in the firing sequence. The exhaust lifter will have already returned and you'll notice the intake lifter will be raised. Slowly turn the engine until the intake fully returns back to it's seated position. You can now adjust the rocker arms for that cylinder. And so on...
Solid lifters, 1.6 shaft mount roller rockers. i already took the inner springs out to break the cam in.
Old 09-07-2010, 02:31 PM
BoxWrenches valve lash adjustment video.
http://www.youtube.com/watch?v=89o5r...eature=related
Old 09-08-2010, 08:23 AM
Thanks for all the insight guys, i can say i actually learned a lot and will be taking everyones advice!
Valve Lash jor Engine 17 09-16-2012 12:52 AM
I lose compression w/ valve adjust drivehard Engine 5 11-23-2009 09:29 AM
how do i set valve lash setting on a 454 85 k5 mud truck Engine 3 06-04-2009 11:06 PM
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Adjusting olds rockers .... HELP A/G WILLYS Engine 7 08-21-2008 12:22 PM
