Running AC compressor without R134a - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-16-2008, 12:05 PM
Pudycat
Working on a new bracket for the AC compressor and was wondering if it would hurt the compressor to run it before adding refrigerant? It did come with oil. I may not want to add refrigerant for quite awhile because of other engine do overs and repainting the engine bay so will I harm anything? Would it make a difference if I have hosed connected or not?
Old 08-16-2008, 12:49 PM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
I don't BELEIVE the clutch on it will engage for more than a second or two with no refrigerent..if you DO turn it on...
sprecher48's Avatar
Oddo nut
Last wiki edit: VW engine basics
Last journal entry: note from the sandpit vol.#3
Location: sunny south(maybe rainy,haven't looked outside today) florida
Wiki Edits: 10
re;a/c compressor
I don't think I would do that unless you have no intention of kicking the compressor on. You can check the compressor clutch by powering up the clutch w/o the engine running & trying to move the clutch by hand,otherwise the pulley just runs on the sealed bearings like the a/c was off. Tom
Old 08-16-2008, 01:16 PM
Providing you do not attempt to engage the clutch, it will run on the nose bearing forever.
Old 08-16-2008, 04:55 PM
SSedan64's Avatar
To be safe just unplug the power wire going to the clutch. That way there's no way it can engage the compressor.
Old 08-16-2008, 06:22 PM
Given how incredibly expensive a compressor failure is to clean up and get out of the airconditioning system, I'd make double sure that thing didn't operate till I was ready to charge the system. The simplest way to do that, short of not installing it, is to not (I said NOT) to connect the clutch connector to the electrical system. That will let the pulley freewheel without engaging the compressor.
Bogie
Old 08-17-2008, 03:03 AM
I third the unhooking of the wires.
Can I replace my ac compressor 99 s-10 briansansone Engine 29 06-22-2008 07:21 PM
My engine is running like crap....I need alittle help batman09 Engine 9 05-06-2006 06:18 AM
1974 Pinto w/ 39k miles... won't stay running. ViperMonster800 Engine 32 04-20-2006 08:09 PM
400 Sbc running warm or not? 84KYSS Engine 16 11-16-2005 04:46 AM
Running Boards toolmansson Body - Exterior 3 05-08-2002 04:05 PM
