Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Running board covers
Old 01-18-2007, 03:46 PM
boatbob2 boatbob2 is offline
boatbob2
running board covers
Hi 38 Special, i put the covers on,right over the primer,(2 coats of epoxy primer) but you could paint the running boards and clear them. i cut a piece of 3/4 in plywood,to the same shape,and put 2 hole cement blocks on the plywood.(it really does take 7 to 10 days to set up.) 5200 doesnt get hard hard, more like a rubber type. if you put some 5200 on a piece of waxed paper,after it cures you can stretch it like rubber. i would use acetone, and remove the self stick,so i would be assured of a good bond. you can remove the excess 5200 by using acetone on a rag.......... im boatbob2
