We use some mild steel tubing from the steel supplier. it is 1/2" OD, .062" wall.
I don't have a picture, but you you leave a small access hole in the frame rail up under the cowl near the brake pedal area(on both sides of the chassis), and the wiring will exit the frame rail inside of the front crossmemeber....then up into the headlight stands, into the grille shell, or whereever else you need to run wiring.
