Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - running different gear ratios in a mudd bogger
Old 05-17-2012, 01:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by inquiring_mind2
I am wanting to run different gear ratio's in my jeep. I use it strictly for mudd boggs. I was wondering if I could run a 410 gear and a 488 gear, I will have the same size tires. I was going to run a 488 and a 513 gear but silly me forgot to order a different carrier to handle that numerically high of a gear. any help would be greatly appreciated
Use the higher ratio (lower number) in the front. Whether the split you want to use is too much or not I have no idea. Be sure to unlock it or pull the front d-shaft before driving on solid ground.
